EPA Net 2 Installation Problem
I just installed EPA Net2 on my computer in a directory called  C:\Program Files\ EPANET2.
When I attempt to launch the program I get an error message that says EPANET2W can't find EPANET2.dll.  But the required .dll file is in the same directory.  Anyone else had this problem and know a solution ?
I'm running Windows XP Home edition.
RE: EPA Net 2 Installation Problem
post this under the computer program forum
Russ
EPAnet was written before 256 charater paths
Install it to an 8.3 directory (like before the win 98)
Hydrae
Thank You Hydrae.  I will try that.  I could use C:\EPANT\ probably ?
That worked Hydrae.  Thanks again !
