IC660BR101B GE FANUC RELAY MODULE SUFFIX
I have a GE Fanuc relay module IC660BR101B mounted in a terminal base with the part number IC660TBR101A. My customer says that the TBR part number should end with the same suffix as the BR part number in order for the module to work.
What is the A (or B) represent. Is it just a series designation? So far, I have not been able to determine the suffix meaning.
thanks,
CTG
RE: IC660BR101B GE FANUC RELAY MODULE SUFFIX
The A and B are versions. Genius blocks are finiky but rugged, try it maybe you'll get lucky.
