Interpretation: VII-1-04-61 Subject: UHX-10(a)
Interpretation VII-1-04-61 states that a no-tubes-in-window (NTIW) baffle design does not fall within the scope of the code for tubesheet calculations on heat exchangers. As a result I must fall back on TEMA for my tubesheet thk calculations, correct?
If so, does the same rule apply to exchangers that do not have a full shell of tubes? i.e. exchangers with large entrance and exit areas or tube patterns which are not "uniformly perforated over the entire nominally circular area" for heat transfer purposes.
RE: Interpretation: VII-1-04-61 Subject: UHX-10(a)
Mike
Konrad
dgrande, no doubt, but we all have HX we need to design NOW.
Actually, I run tubesheets both UHX and TEMA, to try to get a feel for the differences, as my experience with UHX is pretty limited.
Mike
