transformer to solenoid
In order to use a solenoid in a system that is powered by 480vac, we will be using a 480/240 transformer since we cannot find a 480v solenoid.  Does this sound like it may be a problem to anyone?  What things should I consider?
Mark
RE: transformer to solenoid
Usually you would run most of the 'controls' at a lower voltage.  No way to energize this 'other' coil directly with the lower control voltage?  Like with auxiliary contacts or ?
Keith Cress
