Big mass Air COOLING
Dear sirs,
is there any possibilty to cool big quantity of air, that is being blowed by big fans ?
Thanks for your suggestions.
Kindest regards,
vset
Kindest regards,
vset
RE: Big mass Air COOLING
About the largest non-custom blower available is 60,000cfm. Coiling coils can be fabricated to cool depending on your design temperature requirements.
If this is an existing fan with housing you most likely do not have the room to install cooling coils without modifications.
Around 15m3 per second.
vset
The number and size of coils depends on a few variables
final design temp
supply air temp
ambiant air temp
quantity of make-up air
etc
etc
