Difference between Flammable and Explosive Envelopes
I have a system in which there is a mixture of NH3, air, and H2O. After reading a few inter-company reports from the early 70's, I am confused by the way that the report writer and his associates seem to use the term of flammability aand explosive interchangably in regards to an envelope. This is definitely not my area of expertise and I am trying to understand if there is a difference in such a designation.
I found thread798-33615 in this forum from a few years ago, but the questions and comments were not exactly pertaining to this question.
Could someone please explain to me what the difference in terms is, if any?
RE: Difference between Flammable and Explosive Envelopes
http://w
For example, ignition of a flammable methane/air mixture will only result in an explosion if it is confined (e.g. in a building), other wise you will "only" have a flash fire.
As a tutorial I'd recommend reading all the chapters of:
http://ww
apparently it is free upon registration.
You do not even have to register to read the chapters. On the subject they write:
"4.2 Explosion Limits
Same meaning as flammable limits, i.e. UEL = UFL and LEL = LFL. We recommend using the term flammability limit instead of explosion limit."
