Mimimum sq ft for not having suppression
Is there a minimum sq ft reg for not having to install suppression? like less than 200 sg ft ? I read the bathroom and closet stuff. But what about just another small room ?
RE: Mimimum sq ft for not having suppression
is this an apartment, motel/ hotel, house, ????????
And I doubt if any of us know what a Type 1 Suppression Protected Space is.
You need to give us additional information
-- Automatic sprinklers throughout (yes/no)
-- Occupancy
-- Construction type and building area
-- What is the bead blast material?
I hope this helps some.
My take is if you can walk in it sprinkle it. and since the building is sprinkled it should be very simple to sprinkle this room
Is this a room designed to suppress the sound of the blasting???
does it look like this or did some one build a room out of say sheet rock
http://www.titanabrasive.com/blrmspec1.html
Do you knoe the pargaph in NFPA 13 that mentions sprinkler, unless exception ?
