damper rings for stepper motors
NMB stepper motors can be ordered with frame mounts, which basically are 2 metal plates with a rubber ring in between. This "frame mount" or "damper ring" helps keeping sound levels down, and damps some of the nasty vibrations a stepper motor can have.
I cannot find these things anywhere on the web. The rings that are used by NMB are marked "NOK" which seems to be a Far East supplier. But surely there must be more suppliers?
Anyone here knows how these rings are called?
Anyone knows suppliers of these things?
RE: damper rings for stepper motors
All their websites use Macromedia Flash, which I refuse to install again.
Mike Halloran
Pembroke Pines, FL, USA
