Inquire Piping shoe Reinforced Pad General Practice
SS pipe(cryogenic service) cold shoe has reinforced pad. Regarding the thk,I am wondering in field installation the Re-pad is cut from pipe or cut from separated plate.
If the re-pad is gonna cut from pipe I will specify its thk same as pipe schedule; if from plate, I would like to use uniform thk for all repad.
Which way is convenient and economic?
Thanks for your input
RE: Inquire Piping shoe Reinforced Pad General Practice
As I said, typically, so let me give you a couple more things to think about.
For your SS system, I assume your pipe wall is thin, will a re-pad of the same thickness be suitable for your needs?
Also, are these re-pads going to be furnished by the pipe shop, field or separate cold shoe pipe support supplier.
If it's the later, it may be more economical for the pipe support supplier to provide one plate thickness. I recommend that you call a couple of suppliers on your bid list and also check thier catalog.
NozzleTwister
Houston, Texas
Based on your description, there are 3 options:
Option1 : Use that of 42"(largest) pipe thk uniformly, 0.375"
Option2: Break into 4 category, respectively 3/16",0.25",3/8",0.375"
Option3: Use the same as pipe wall thk
Most likely re-pad is with shoe so I will contact with pipe support vendor on this.
