reversing a colormap
Can I do that? If I want, say the 'gray' colormap to be from 'white to black', instead 'black to white', is there any simple function doing that?
Thanks!
RE: reversing a colormap
This should do the trick
CODE
blackwhite = colormap('gray');
whiteblack = flipud(blackwhite);
Hi, thank you for your advice. I know it's been a while since I posted it, but still thank you very much.
