roughly estimate mechanical seal flow requirement
I need to estimate mechanical seal flow requirements for a project's worth of centrifugal pumps, so that, with an applied margin, I can specify seal water circulation pumps, pumping tanks, line sizes, etc., etc.. I have some estimates from a previous plant plant design, but that plant is about three times the normal flowsheet flow of the present plant in question.
How can I roughly, but quickly do this estimate, and can I use the past data: how can I scale it down?
regards
Leclerc
regards
Leclerc
RE: roughly estimate mechanical seal flow requirement
