CAN Termination resistor
Hello all,
I'm looking for a standard automotive CAN Bus termination resistor to implement in a wire harness. I know that a 120 Ohms resistor is needed at each end of the bus to isolate it from noise. I have 3 nodes on the bus and only one is terminated. Since this goes for several units, welding a standard resistor between the 2 cables is not acceptable.
Therefore, if you have any clue on connectors featuring such termination or anything else, it would be really appreciated.
Best regards,
JB
Best regards,
JB
RE: CAN Termination resistor
