Laptop dilemma
Laptop dilemma
Laptop dilemma
I need some suggestions on the best "off the shelf" laptop to run swx '06 and AutoCad '06.  I Don't want to spend alot of money only to find that my assembly won't rotate after only 50 parts or so.
                     Thanks in advance,
                         T. Phillips
p.s.
I checked FAQ's before posting this question.
RE: Laptop dilemma
Prior to my present laptop, I used a Compaq Presario for SW '06, and it worked fine. Maybe not as quick as one would like, but it did work. I did max out the RAM at 1.25GB. It had an nVidia Go graphics card and, though not necessarily approved, it did work.
What's "a lot of money"?
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
RE: Laptop dilemma
Remember if you find one that does work for SW06, doesn't mean it will still work on SW07 or future versions, because SW becomes more and more demanding on Hardware per each version. If you hardware is not certified, then there is a good chance that your Laptop will crap out sooner, then if you went ahead and spent the money for a good one.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
