Surface Profile with One datum reference - Legal?
I am a Manufacturing Engineer struggling with the interpretation of our design group as it seems they constantly push the boundaries of what my concepts of GD&T, and interpretations are. As for the question...
I have a standard panel part with a thickness. This part has several holes and a datum structure as follows. Datum -A- is a plane on the bottom surface. Datum -B- and -C- are hole features. The remaining hole features are controlled to Datums A|B|C with MMC respectively. Then I have an internal cutout feature that is basically an internal rectangle that goes thru the part. This feature is controlled with basic dimensions but called out with a surface profile with respect only to Datum -A-. Is this legal? What is truly controlling the location of this surface feature if datum -A- is a plane perpendicular to the features surface. Hope someone can help with this one...
___________________________________
| ___ |
| |___| |
|__________________________________|
joejack7
| ___ |
| |___| |
joejack7
RE: Surface Profile with One datum reference - Legal?
Controlling the profile w.r.t. "A" will control the shape of the cutout, but not the position or orientation.
Jim Sykes, P.Eng, GDTP-S
Profile Services
CAD-Documentation-GD&T-Product Development
www.profileservices.ca
I believe your cutout MUST have locating dimensions and tolerances, and if size is basic dimensioned, it would require Locating datum features.
Ron
Profile Services
