Material properties: why separate visual from analytical?
It seems that in NX4 and earlier, the application of material properties for visualization purposes (ie: Studio display, rendering) is not linked at all to the application of material properties for analytical purposes (ie: density, mass calculation, inertia, strength, FEA).
Why is this so? In Catia, the application of material properties is done ONCE, and it affects both visual properties as well as physical properties. The user can add new materials too, with a reasonably easy to use GUI.
I think this is one of those obvious things that NX should be capable of doing. Seems like you could just add in a set of new properties to the already-existing Materials Palette, so that in addition to the rendering props, you have physical props.
(Of course, if I'm totally off base here and NX already does this, then great, can you please tell me how?)
RE: Material properties: why separate visual from analytical?
John R. Baker, P.E.
Product "Evangelist"
NX Product Line
UGS Corp
Cypress, CA
http://www.ugs.com
