SolidWorks & Pro/E Translating Software?
3
This is my first post/Thread - so don't be gentle, if I'm asking a silly question then shoot me down with both barrels.
I’m looking for some type of interpreting or translating software that works with Pro/E and Solidworks.
Here’s why and I’ll try to keep it short: The Company I work with uses Solidworks, unfortunately the one of our vendors we do a lot of business with in Brazil use Pro/E. When they send me a model I’m able to open it and see the various components of the assembly, but not the attributes associated to it. When I send them a model, all they see is a solid block. Both companies have tried saving models under various extensions but we haven’t found the right combination yet, so here I am.
Does such software exist? Mine is an average skill-set at best with SolidWorks so perhaps I’m doing something wrong on my end?
Any help would be more then appreciated.
RE: SolidWorks & Pro/E Translating Software?
There are several companies that have software that can do native to native conversions. Translation Technology Inc. (www.translationtech.com) offers one such product.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2006 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
SW07 can import and export Pro/E format files;
Quote:
Versions 17 through 2001 of Pro/ENGINEER and Wildfire versions 1 and 2 are supported
I don't believe the properties (attributes) are carried through the conversion process. A quick test (exporting & importing from & to SW) did NOT bring in the properties.
cheers
Also, their are definite feature differences that will hinder conversion.  I've tried importing Pro/E 2001 files into SWx but remember SWx doesn't have a variable section sweep.  So it depends on the complexity of the geometry.
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
      o
  _`\(,_
(_)/ (_)
