CATIA V5 and using VB6
Can anyone tell me if you can use VB6 within CATIA V5?  Natively it uses VBA which does not appear to use PropertyBag's.
If you can use VB6 within CATIA V5 then how do you do this?
RE: CATIA V5 and using VB6
I prefer to use late-binding with VB6 and Catia. Although it is supposed to run slower, you'll find that it is Catia that runs slow and you won't notice the difference between early-binding and late-binding. If these terms are new to you they are covered in the VB docs, so you should read up on them.
The other advantage of late-binding is that you do not need to recompile code between Catia releases, unless the functionality that you are using has changed.
So, with late binding...
'In a module declaration section:
Global CATIA As Object
Then something like this:
Public Function GetCatia() As Boolean
    GetCatia = False
    If QUIT = False Then
        If CATIA Is Nothing Then
            On Error Resume Next
            Set CATIA = GetObject(, "CATIA.Application")
            If Err.Number <> 0 Then
                msg = "Cannot find Catia. Please start Catia and then run the application."
                msg = msg & vbCrLf & "Do you want to quit?"
                res = MsgBox(msg, vbCritical + vbSystemModal + vbYesNo, "Cannot find Catia")
                If res = vbYes Then
                    QUIT = True
                End If
            Else
                GetCatia = True
            End If
        Else
            GetCatia = True
        End If
    End If
End Function
If you want to use early binding you can find more information in the on-line documentation. See
V5Automation.chm in the bin directory of your Catia path for more information.
Andy
So basically, you are using VB6 to run CATIA if it is not running like any other program (I've used VB6 to run Word and Excel and Access before) and then controlling it with VB instead of CATIA controlling VBA.
Sounds good, thanks for the clear post with code. Code always helps!
