OFFSET XSECTION DISPLAY
I am having a problem getting an offset xsection to display correctly in a drawing. Sometimes all I see is the xhatching, other times the xsection fails when I try to use it in a drawing view. It seems to work if I'm careful not to sketch the xsection on a centerline. This is an assembly in version 2001. One thing I noticed is that the parts in this assembly were created without symmetry constraints, could that be part of the problem?
