CBUSH Rotational stiffness calculation
Does anyone have any reference(s) to calculate the rotational stiffness for CBUSH in FEM to account for the moments due to the heel-to-toe effect for a L-angle?
RE: CBUSH Rotational stiffness calculation
So the approach we took was to use a more conventional CBUSH plus CGAP FEM approach and then match the shear and pull-thru forces along the flange using variable in Rx. We found a value that matched pretty good, although it differed from other siuppliers assumptions.
I suggest you use a test FEM to make a comparison analysis and then use the value of Rx that gives best correlation.
