Hydrogen sulphide& CO2 removal of grondwater with degassing
A lower pH assits in Hydrogen Suphide removal from groundwater if degassing used this will also drive off CO2 making Hydrogen Sulphides Harder to remove by increasing pH.Is there other method of removing hydrogen sulphides before degassing CO2 such as Ozone?
RE: Hydrogen sulphide& CO2 removal of grondwater with degassing
thread164-165833 for example may help you.
S. Bush
www.water-eg.com
The most common removal method would be aeration or degasification, and/or chlorination. Chlorination is most economically applied to remove the residual after aeration. Lowering the pH will work, but whether it is practical or not depends on the particular application.
