Pressure Treated Stress Losses
Anyone have these values?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
Pressure Treated Stress LossesPressure Treated Stress Losses(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Pressure Treated Stress Losses
PT engineered wood products do have a reduction in strength. Do you think the preservative treatment weakens the glue used in engineered wood products?
They are now producing pressure treated "Parallam" beams with reduced strength factors, probably to allow for reduction in the strength of the glue, as you presume. It will be interesting to see how these products weather in the next ten years.
The use of proper fasteners and connectors for treated wood framing is also very important. Standard carbon steel nails and fasteners may rust and corrode with time causing unsightly stains and possibly an eventual failure to hold securely. When building with pressure-treated, use hot-dipped galvanized or stainless steel nails and fasteners that are manufactured to resist corrosion. (Note: mechanical-galvanized nails may be adequate for enclosed interior treated framing applications only). All connecting hardware such as joist hangers, hurricane straps, lag screws, and bolts should also be galvanized.
