How to calculate water vapor in air
Greetings...
I want to avoid the use of psychrometric charts, but I have information of air wet and dry bulb temperature. What is the formula that will allow me to calculate the humidity, so I can then calculate the quantity of water vapor in the air. If you do not have the formula handy, at least let me know, any references where I can find it. Thanks in advance. Happy Holidays...
RE: How to calculate water vapor in air
Good luck,
Latexman
I2I
Costs a few dollars, but if you really want. . . .
http://www.linric.com/products.asp
They have a few options for you.
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
