Steam-Air Preheater
Steam-Air Preheater
I need to perform a cross-check of steam/air preheater design calculation. Exchanger purpose is to preheat 100,000Nm3/h of combustion air for CDU process heater. Calculated air pressure drop is 25mmH2O, which is reasonable.
I need information about empirical heat fluxes and overall heat transfer coefficients, employed in steam/air preheater design. I found many contradictory values in the literature, for flux as high as 20kW/m2 and as low as 4kW/m2.
I do not have experience in steam/air services, so any help or guidance would be appreciated.
Best regards
Best regards
RE: Steam-Air Preheater
rmw
