Drawing a thread in AutoCAD
Does anyone have a routine for drawing a screw thread in AutoCAD?  I have an AutoLISP routine for a coil but it won't draw a true thread shape easily.
Cheers in advance,
Chris.
RE: Drawing a thread in AutoCAD
Chris, are you working in 2D? If so why not just draw the OD and ID to show a thread, it is the industry standard and how most (if not all) 3D packages show threads as 2D drawings?
CODE
http://new.cadalyst.com/code/browseyear.cfm?fullyear=1993
http://discussion.autodesk.com/thread.jspa?messageID=279217
http://www.caddigest.com/subjects/autocad/tutorials/select/SCREWS/SCREWS3.HTM
http://management.cadalyst.com/cadman/article/articleDetail.jsp?id=101140
Many more available if you use a search engine.
But I agree the plain jane 4-dashed line 2D version is the best all around way to draw a thread.
Business Card     http://mech.e.tripod.com
__________________________________________
Cycle Heaven.......www.tailofthedragon.com
