Interpreting requirements?
Hi
I need to perform vibration and shock analysis for a rather large crate - 3.1*.5 sq. meters. I have some data in the form of vibration specrtum, and a grms value. I do not have the PSD/ASD graph, or any values from it.
here is an excerpt from the specs:
Vibration:
Truck Transportation Frequency Range: 10 to 500Hz
Random Vibration Level :
Vertical (Z) - 1.04 Grms
Transverse (Y) - 0.20 Grms,
Longitudinal (X) - 0.70 Grms
Restrained cargo, At the Shipping Crate Base
MIL-STD-810F, Method 514.5, Procedure I, category 4
System Required to Operate after Exposed to Vibration
Shock:
Half Sine, 10Gpeak, 10msec
Estimated from Shock Spectrum F.E. Ostram "A Survey of the Transportation and Vibration Input to Cargo" Shock and Vibration Bulletin #42(5), 1972, pp137-151
I'm using MSC/NASTRAN and PATRAN for the simulation, but I only need to know how to interprt the requirements into something more understandable.
Vibration:
Shock:
RE: Interpreting requirements?
Tom Irvine
www.vibrationdata.com
Longitudinal
Freq(Hz) PSD(G^2/Hz)
10 0.00650
20 0.00650
120 0.00020
121 0.00300
200 0.00300
240 0.00150
340 0.00003
500 0.00015
Transverse
10 0.00013
20 0.00065
30 0.00065
78 0.00002
79 0.00019
120 0.00019
500 0.00001
Vertical
10 0.015
40 0.015
500 0.00015
I got my hands on the mil-std-810.
I have a few other spectrums, which are shown in a graph, not in a table like the truck spectrum.
How can I convert the graph to a table?
TIA
Jake.
Do you have access to Matlab?
If so, I can provide a script.
Tom Irvine
I have access to MATLAB.
How do I need to scan those pics? I have the PDF version so I can just extract the graph.
thanks again
Jake.
For example, you can copy the graph from the PDF document. Then paste into MS Paint. You can then save the image as a bmp or jpg file.
Then import the image into Matlab.
Tom Irvine
