Mathcad version 12 , ugly comment !!
I have a file under mathcad version 12.
I am using an indice (i) ranging from say 1 to 10 , with a step = 1...so in my file I am calculating several values for each step..
I am actually satisfied with the results.
The problem is when I want to preview or print the file..I see a sort of zig-zig or criss cross green line under each value..ugly eehh..The comment I got from mathcad when pointing a value is " This expression defines a previous defined variable".
The question is how to get rid of these ugly cris crosses and this comment ?
It is not nice to show this to a client..
I do not have- had this when working under version 2000 or previuous versions !!
RE: Mathcad version 12 , ugly comment !!
Go into Tools, Preferneces, Warnings, and turn warnings off. MathCad is just trying to tell you that you've redefined either a built-in variable or a user-defined variable.
David
Each successive version of Mathcad has had an increase in the number of built-in units, so knowing that you've redefined something is pretty important.
That said, I would suggest that if you've just recently purchased M12, to try and get M13 in exchange. M12 does indeed have a lot of bugs.
TTFN
Bung
Life is non-linear...
