Converting to Autocad geomtry inacuracies
When I convert a Soliddraw file to a dwg file, my geometry is not matching the original file. If I measure a dimension, and this happens in dwg editor or in acad, I will get dimensions different from the originals. Also when using the converted drawing views as blocks, and then trying to locate those blocks using the existing geometry I get errors as well. I am using version SW2007
Does this happen to anyone else? Is there a fix, or is this a issue with the settings?
Halfmark
Halfmark
RE: Converting to Autocad geomtry inacuracies
That's probably the first thing to check.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Save as > dwg > options > scale options
http:
SW07 SP2.0
Flores
export options:
version r2004-2006
fonts: Autocad STANDARD only
line: Autocad standard Styles
scale output 1:1
base scale: sheet scale + 1:1/1:count=1
Enabled x
warn me if enabled x
end point merging enabled
export all splines as polly lines
export active sheet only
thank you all for your help!!!
How do the measurements compare when the file is opened in DWGeditor?
no diiference witg dwg editor
however I opened the sketch of the solid model the drawing is of that dimension was corect and I checked it to 8 places just to be sure I was not having a issue with rounding. The dimension was correct. I then deleted it and redimensioned the exact same number. The conversion of that was correct
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
