AB T47 Programming Terminal BIOS
I was given a T47 to test and on power up it says: Invalid configuration information - please run SETUP program. Is this the BIOS setup? It appears that the hard drive is bad, but I'm not sure yet.
Is there a way to get into the BIOS and look at the boot sequence. The floppy drive works. When you try the 'C' prompt, it comes back with: Invalid drive specification.
Any help appreciated.
thanks,
CTG
thanks,
CTG
RE: AB T47 Programming Terminal BIOS
I believe you need the Configuration floppy to get into the bios settings.
CTG
http://forums.mrplc.com/index.php?download=662
