Callout Text aspect ratio
I am using V19. I have callout text in my titleblock and it is pulling info from file properties. I need to have the text maintain its height, but I need to change the width, basically make it narrow to fit inside the box. Is there a way to do this? I've been looking and trying and can't find anything.
Thanks!
RE: Callout Text aspect ratio
you can't change that because it's how the font is designed. For
instance Verdana is wider than Arial. You have to choose a
different font which is narrower at a given height (i.e often
described as condensed). Any TrueType font can be used.
dy
