Bending plastic
Bending plastic
We make a plastic part that we bend by first machining a V-groove in it with a 90 degree included end mill, then heat the plastic and bend the edges of the V-groove together.
Does anyone know of a simple method to design this with the sheet metal part of Inventor so that you can get a flat layout?
I have come up with a work around to get the results I want, but was wondering if there was a simpler way to do it that I'm not seeing.
I see this topic has been discussed before (thread790-154340), but it doesn't appear that any solution has been given.
Thanks in advance to anyone who can help.
RE: Bending plastic
RE: Bending plastic
RE: Bending plastic
