Digester Gas Flow Switch
I'm looking for a flow switch to be mounted downstream of existing gas compressors to confirm operation / detect failure. I'm reluctant to use a thermal flow switch because of possibility of grease build up etc. The pipe is 2" steel
Can anyone suggest a reliable instrument?
RE: Digester Gas Flow Switch
will the pressure go to zero if compressors have failed? Pressure switch may be better
Richard A. Cornelius, P.E.
WWW.amlinereast.com
