Carbon Arc Gouging on 316L stainless
I want to cut a fitting off of a 16" O.D. flange by removing the welds. This is a perfect application for carbon arc gouging but the catch is the flange and fitting are 316L stainless. Will it ruin the stainless because of the heat or can the cutting conditions be changed enough to make it work out? This is a situation where the corrosion resistance of the stainless is important. My other options are grinding, plasma arc cutting, or maybe waterjeting if I can talk the waterjet owner into it.
What do you think?
Stonecold
What do you think?
Stonecold
RE: Carbon Arc Gouging on 316L stainless
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Stonecold
Keep your carbon stick out short...and make sure the air holes are on the bottom
of IGC SS around. In our fab shop we allow both carbon arc gouging and washing with a TIG torch. With a very minimum of grinding we see no detrimental performance in the weld proper or the HAZ in service.
We allow arc gouging on process vessels where we discover less than satisfactory weld metal performance. There is usually no other preparation. We also repair thermal fatigue cracks on SS vessels by the same method.
Early on, 1960 I ran numerous lab and field tests comparing there methods for cutting SS, iron powder torch, carbon arc gouging, washing with a TIG torch.
The initial test were run using both 316L and 304L with carbon at 0.035 max. With no other prep there was some difference in weld performance in the Huey Test. Some of the difference was confirmed to be for the variability in the electrode as deposited chemistry. Repeating the test with the base metal carbon limited to 0.030 max and using an electrode with a deposit analysis of .035 max carbon results were vastly improved. Changing the base metal to 0.020 max carbon with an electrode with 0.025 max carbon
there was no discernible difference in the corrosion behaviour. Striker tests of sectioned coupons no increase in precipitation at the grain boundaries. The last test coupons were installed in process. These coupons
were made for SS with a max carbon of 0.015 with the both S and P controlled. They showed no effect of either arc gouging or washing by TIG torch.
We still allow back gouging in the fabrication of SS storage tanks even though the plate is cut with plasma. All tanks are welded with SMAW with full penetration and 100% RT.
We do reserve the right to monitor the performance of the person doing the arc gouging. We have a qualification procedure for our people. It has been experience that 90% of the people who try arc gouging are given the torch and told to go at it.
I afreed that plasma is the way to go but ther are time it's hard to get away from arc gouging.
