API 5B Long Line Pipe Threads
Several years back API listed a NPT thread called long line pipe - basically the start of taper is smaller and the diameter at the hand tight plane is the same.  The L1 dimension is longer than a standard NPT.
Does anyone have the old copy of API - I'm guessing it was published in the 1970's.
Does anyone know the offset for the 2 inch size?
roadapple
