On Nonlinear Conductive Heat Transfer Equation
I am looking for an analytical solution to the 1D nonlinear heat transfer equation
d^2T/d^2X = c(T) dT/dX
as you can see nonlinearity appears as c is function of temperature; i.e c(T). I want analytical solution . Can you guid me to a sourec where I find the analtical solution of this 1D difuusion equation.
I already posted this in Heat Transfer Forum.
RE: On Nonlinear Conductive Heat Transfer Equation
your only hope might be a numerical solution.
Cheers
Greg Locock
p=dT/dx and dp/dx=d^2T/dx^2
Then
d^2T/dx^2=dp/dT*dT/dx=pdp/dT=c(T)*p
Dividing by p
dp/dT=C(T)
And
dp=C(T)dT Integrating both sides
p=F(T)+K where F(T) is the integral of RHS and K is a constant
dT/dx= F(T)+K
dT/[F(T)+K]=dx
integrate again to get x as a function of T
d/dx{K(T)dT/dx}=0
which becomes
K(T)d^2T/dx^2+ dK/dT*(dT/dx)(dT/dX)=0
and if you call -1/K*dK/dT=C(T) you get
d^2T/dx^2=C(T)[dT/dx]^2
Note the square term on the RHS, not what you got. The method of solution is similarto whatI showed. You now get
dp/p=C(T)dT for openers.
C(T) =(dS/dT) * T + S + A(dS/dT)
Where A is constant and S is an emperical function of T ( based on the Lab data, the best relation suggested in literature is S= B(C/T)^D, where B,C,D are fitting parameters)
However if makes life easy, I can assume this emperical function ,say Polynomial
Of Course as Prost says it is difussion equation
d^2T/d^2X = c(T) dT/dt
If one of you is aware of a possible existance of an analytical solution (even if approxinate). please refer me to the source. PLease note that its BCs is also nonlinear .
It is a challenge .. is not it.?
jdm
"Education is what remains after one has forgotten everything he learned in school." Albert Einstein
is not Galerkin expansion based on Finite Difference (numerical approach) ?
jdm
jdm
Excuse me, but under my definition of analytical, this will NOT be an analytical solution. He may as well do it piecewise numerical and be done with it.
corus
From MathWorld:
A real function is said to be analytic if it possesses derivatives of all orders and agrees with its Taylor series in a neighborhood of every point.
By this definition if the weight functions were chosen as say trig functions he would have an analytic solution.
But, maybe I am misunderstanding what he means by analytic solution. For his problem there is not an analytic solution, by which I mean you just cannot solve it, but you can generate a closed form approximate solution.
He could also use a perturbation (expansion) techinque such as a Poincare map, or multiple time scales analysis to gain some insight of the system.
And I do agree that a numerical solution would probably be the most effective way of solving the problem, but he was not asking about numerical techniques.
jdm
From MathWorld:
But, maybe I am misunderstanding what he means by analytic solution. For his problem there is not an analytic solution, by which I mean you just cannot solve it, but you can generate a closed form approximate solution."
It may interest you to know that a differential equation can have analytic coefficients and still be nonlinear and generally, not solvable analytically.It depends on whether or not the coefficients are functions of the independent variable or not.
jdm
It is simple and analytical (requires no descritization) If you have experience using it what do you think of it.
It is simple and analytical (requires no descritization) If you have experience using it what do you think of it.'
I haven't seen it, but will venture to say it will NOT solve analytically any general class of nonlinear PDE of the type we are discussing, or hardly any of any class.
You say it is simple, so let's have an example since access to a 1960s book is almost impossible.
let me tell what I am doing regading this issue so that we can share knowledge. As you know that the nonlinear equation is d^2T/d^2x=C*dT/dt
and the nasty C(T) =(dS/dT) * T + S + A(dS/dT). Now if the relation between S and T is emperical (fitting curve),why not find S=f(T) for which
(dS/dT) * T + S + A(dS/dT)= constant (C) So I am just solving this equation so that I will get families of S =f(t)for which the nonlinear equation above becomes linear
afterwards I will optimize the constants of this simple differentail equations to find the best curve that fits my emperical data S and T. Makes sense to you.Your comment is appreciated
P.S zekeman: you can find info about Integral Methods for NLHT problem in any HT book
Why are you going through all this labor? What is wrong with a numerical solution?
If you can share this with us, what is the application? Maybe one of us could shed some light on it.
And by the way, I am aware of integral methods, but they will not solve general nonlinear PDEs as I mentioned. Want to win a Nobel Prize in mathematics, just find a general solution to your problem. Oh, they don't give the prize in mathematics, so make it a problem in economics and then you may.
Good luck.
Well the idea of trying to get T given in an analytical formula is because I am going to use it in another close formula. Plus you talk about developing numerical solution as if it were piece of cake and requires few minutes to finish without any troubles.
P.S. I have no intention now to develop Zekeman's (or soory Goodman's) Integral Method in heat transfer But if i decide and win Nobel price I will give you some bucks
You stated that C(T)=(dS/dT)*T + S +A(dS/dT). I am quiet certain that dS and dX are the same, therefore, plugging c(T) in your equation d^2T/dX^2 would yield
d^2T/dX^2 = T + A + X(T)dT/dX
which could be solved adding the results of Esbach's case 1 and case 3 the latter being shown by Zekman in your reply.
T" = x(T)T'+T+A; A is a constant per your definition
let T+A=I(P*dX); I is the symbol for integral
differentiate T+A becoming dT=PdX then P'= T"
make substitution to above DE: P'=x(T)P+I(pdX)
then: P'/P=x(T)+(I(PdX))/P
=x(T)+I(dX)
then: dP/P=x(T)dX+(I(dX))dX
I(dP/P)=I(x(T)dX)+I(I(dX))dX
since x(T)=F(T) then dx=f(T)dT
I(x(T)dX)=I(F(T)dT)
Final differential equation:
I(dP/P)=I(F(T)dT)+I(I(dX))dX
Make sure imits of integrations are appropriately changed.
I do not think CSAPL meant in his equation that dS and dX are the same" Why you said "I am quiet certain dS and dX are not the same. According to CSAPL explaination S is a function of T while X is the coordinate
CSAPL can correct me if i am wrong
