Best way to seal steam boiler threads
In my past experiance we have used teflon tape and teflon paste for best results in sealing steam boiler threads up to 100psi. Is thier any spec. that states the best way to seal pipes that are heated and cooled down on a regular basis? We have a new QC guy in that is trying to go to a paste product only. and in doing so we are springing leaks all over. ( don't touch what's not broken) I was just wondering if there was a tape and dope spec. as a standard out there.
RE: Best way to seal steam boiler threads
I know of no Industry Code or Standard that goes so far as to say what thread compound or tape or lubricant should be used. That call is pretty much up to the end user or someone in the end users' employ.
I've always used rectorseal #5. It conforms to TT-s1732.
The anaerobic thread sealants such as those made by Henkel "Loctite" are flexible to handle the thermal expansion/contraction problems that tape alone may not seal reliably long-term.
