define symbols
define symbols
define symbols
Hi All,
I new to Wildfire 3 from ProE2001. A lot has changed but mostly same functions.  Can you define a balloon symbol to call up ASM.MBR.NAME by adding :X (X= some internal id)?
Another question.
In sheet metal, we have map keys set up to load the sheet AWG and bend tables for each, is there a config.pro setting to default the bend raduis by parameter in the dash board instead of by thickness?
TIA for any help
Tofflemire
RE: define symbols
> ... :x
:x = sid# (or cid#, they're equivalent, I think)
Tools -> Relations -> Show -> Session ID
I think it'll have to be something like
&part_param:xx, though, as there is not (?)
a way to link to a repeat region to get asm.mbr.*
in a note or symbol (notes work, var text symbols?).
