Custom Radiator OEM's
I have an applicaiton that requires a custom made radiator for a diesel engine. Our current engine supplier uses a radiator manufacturer that is at best, lacking in support and turn-around. I am in search for suggestions for an OEM manufacturer of radiators to custom specs. Qty's can range from 1 to 50, depending on the customer. The OEM should be able to respond quickly to our inputs AND work with us in trying to determine a solution for custom applicaitons.
Any vendor suggestions?
Thanks in advance.
Bill
Thanks in advance.
Bill
RE: Custom Radiator OEM's
-Reid H
Who did you speak with at Active? I didn't have much support with my sales/tech rep. The radiator turned out well, but I wasn't completely satisfied with their service.
-Reidh
-Reidh
http://www.copar.net/
www.webskl.com
Good Luck
J.L.
