Computer harddisk
Computer harddisk
Hi all,
I am interested in the data stored on a harddisk which is out of an aircraft accident. The harddisk was highly damaged during the accident. The r/w-heads crashed on the disks and caused severe damage to the disks in that area. However, the remaining area of the disks seem to be fairly intact. I talked to a company which specializes in recovery of harddisk data and they basically say that they can only recover data as long they can still rotate the disk under a head. Is anyone aware of other methods where it is possible to only read some areas on the disk? Just curious.
Phil
Phil
RE: Computer harddisk
I don't recall anything about the process other than it was applicable only for certain types of drives and was extremely expensive. I got the lead through the Computer Shopper Magazine.
I inquired about about this for a 10 meg drive that crashed. The drive made no sound when powered up and evidently wasn't spinning so the inquiry. This was when a 10 meg drive cost around $250.00. The drive was brought back to life by raising it 18" off a wooden bench and dropping it.
Googling "data recovery" it looks like there a quite a few companies that may be able to get at your data.
There are more expensive alternatives, particularly those used in magnetic bubble memories to determine the orientation of magnetic domains. As this is a slow and labor intensive process, its cost is commensurate.
TTFN
Dik
