AWS D1.6 1999 Qualification
I am currently reading AWS D1.6 1999 cover to cover and I am new to this site. I cannot find anything about welding certification within it. Is a welder required to have been certified to perform the welding? If so, what are the requirements?
RE: AWS D1.6 1999 Qualification
As "henri2" noted above his reference is correct.  Also remember the WPS that the welder is using must either be "prequalified" or qualified under Section 3 or Section 4, respectively.
Allen
Sindel & Associates
www.consulting.awsindel.org
Thanks for the help.
