Hydraulic Ram Manufacturers
Hey,
Me and my father are developing a robot to compete in the UK television series "Robot Wars". The robot is designed using a hydraulic ram of approximate bore 3" (75mm) with 400mm of stroke. It will operate up to a maximum pressure of 3000 PSI (the limit within the rules). If anyone can offer links to companies that might supply suitable rams/pumps/valves it would be greatly appreciated...
Cheers
Lloydy
Cheers
Lloydy
RE: Hydraulic Ram Manufacturers
