Lug under tranverse load formula question
Hi there,
Little question here. Usually, to calculate the allowable load for a lug under transverse load, you have to calculate and average area of the section of the lug.
The formule is : Aavg = 6/(3/A1+1/A2+1/A3+1/A4).
Here's my question. In all the books and references, they show without explaining it, that A1 and A4 are area at a 45 degree from center the lug and I am assuming that A1 is always in direction of the load. Is that a correct assumption? I have a lug which is straight at the bottom and 45 degress on the top and my tranverse load is in the straight direction, so is A1 always the area in the load direction or A1 is always the biggest area because of the factor (3/A1) ?
Thanks!
Thanks!
RE: Lug under tranverse load formula question
