helo friends
helo friends
helo friends
Helo friends throw me some light
I would like to know the acceptable tolerance levels in centrifugal pump performance as per ISO 9906 Anex 2A when compared to ISO 9906 Anex A.
RE: helo friends
hello friend81, I can't answer your question, but here is some advice anyway. Try to use a more descriptive heading for your questions, and you will find you will get more relevant advice. Perhaps the guy who is an expert on ISO9906 wasn't in the mood to say hello to friends today, but if he had seen the subject heading "Pump performance tolerance per ISO9906" he may have opened your query and given you a good answer.
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
RE: helo friends
Dear Katmar
Thanks for your suggestion actually that was a mistake which i failed to check before submitting the thread.
