Velocity difference between high point and low point
Dear all,
I need help.
Given:
1. There are two points. One of them is 1 meter higher than the other.
2. Water goes from the high point to the low point by gravity.
I want to know whether the velocity of the low point is constant or not regardless of the length of two points.
Any help would be appreciated.
I need help.
Given:
RE: Velocity difference between high point and low point
I modified some contents a little bit.
Dear all,
I need help.
Given:
I want to know whether the water velocity at the low point is constant or not regardless of the length of two points.
Do you mean the distance between the two points?
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
BigInch
BigInch
