young's modulus
young's modulus
young's modulus
Hi everyone,
does the modulus of elasticity of steel vary with yeild strength???
I am working on astructure that is to be built with Grade 70 weathering steel (Fy=70ksi) is the "E" value 29000000psi or higer??
I really would appreciate your respose
Thank you all
RE: young's modulus
Some references give the value of E as 29 million psi, 29.5 million psi, or 30 million psi.  However E is independent of the Yield Stress.
RE: young's modulus
Thanks eureka,
that is what i have always known and thought but I have seen the value of 40 million psi in several places for grade 70 which is got me wondering,
thanks though.
RE: young's modulus
What about the E of stainless?>
RE: young's modulus
FYI, the E of steel strand and rope is less due the "spring" effect of the rope/strand twist/helix...
E strand is about 20,000 ksi
E rope is about 25,000 ksi
BUT...the E of high tensile THREADED bar (ASTM A722) varies excessively from ASTM standard value of 29,700 ksi.
RE: young's modulus
It would seem that using the lesser value of 29ksi would be conservative.
