Drawing of spur gears
I'm interested in drawing a pair of spur gears, one of which
is small, and contained within the other, while engaging it.
For my purposes (concept), the sizes are not critical. I have been unable to locate an AutoCAD (.dwg) or .dxf drawing
of any spur gears. Can anyone e-mail to me an AutoCAD or .dxf drawing of a spur gear, showing the teeth? Thank
you very much.
Andrew Lampenfeld, aka inventorandrew
you very much.
RE: Drawing of spur gears
description. I want to draw a "generic" spur gear with
perhaps 8 teeth on its outer circumference. I also want
to draw a second gear (ring gear? I'm not sure about the
terminology) that surrounds the first gear. The second
gear will have an inner circumference that has teeth
compatible with the teeth of the first gear. The second
gear has approximately 4 times the number of teeth as
the first gear. Hope this helps. I just want to draw
these things accurately, by utilizing already-drawn
hardware. Thanks for any help you can provide. Any
drawing in .dxf format would be useable. It doesn't
have to be AutoCAD specifically. Most CAD programs have
a feature that allows a drawing to be converted to .dxf
format. Inventorandrew
lack experience with involute gears. Any size would be
okay--I can modify it later. It's for an invention of a
tool for mechanics. Andy Lampenfeld
I have such program , it run in excel and generate a Script file to be automaticaly drawing by ACAD R14 more.
Please e-mail me I will send it you
You can reach me at k281969@hotmail.com
but keep your post here for mutual benefits.
Pardal
This link should help you out, since you know autoCAD. I was going to do some drawings for you but I just got handed a large project that's taking too much time...very sorry.
-james
Pardal
please contact me at the
k281969@hotmail.com.
I have a lisp to draw the first half profile of a gear locatet at the pitc circle , from there you can finish the gear
Pardal
