Bottom Chord Bracing
I am investigating some existing wood roof trusses for the owner to verify that they are structurally sound. The trusses are about 30 years old, comprised of 5-1/8"
wide glulam members with bolted side plates at the panel points, about 65 feet long and spaced at 20 feet on center. They are a simple type truss with a constant sloping
top chord and a horizontal bottom chord, (and web members between). The top chord is braced by the wood roof framing, and there appears to be no visual distress in the truss members or connections.
My question to you is: Is there any requirement, (code wise or standard of the industry),that the bottom chord needs to be braced? The bottom chord will always be in tension,
even when acted on by earthquake or wind forces, and there is no diaphragm action requirted of the bottom chord.
Thanks in advance for your response.
Larry Hauer, Structural Engineer
RE: Bottom Chord Bracing
The engineers that mentored me generally would not brace a bc that was always in tension. A rule of thumb I was taught was when in doubt don't. This rule of course is the opposite of the typical structural enginnering rule of when in doubt make it stout.
I was taught not to add bracing to the bottom chord unless I had a reason to do so. Common reasons to brace the bottom chord would be would be stress reversals and the need to transfer a lateral force through the system.
In Appendix A of the NDS there are some non-mandatory provisions for bracing trusses. Based on experince those I work with don't follow those provisions.
With your existing trusses, since you are not seeing signs of distress I would not woory about the lack of bottom chord bracing. One key things to look for is excessive truss deflection.
Also if you do a search on this web site you should be able to find a past thread that also discuss bottom chord truss bracing.
Any other thoughts on this, (bracing the ends of the compression web members)?
Thanks in advance,
Larry Hauer SE
When I discussed this with one of the retired company engineers, I worked with in the past, he idicated in over 30 years of practice he had never seen a problem with a heavy timber truss. He also stated that he had a hard time visualizing the bottom tension chord being pushed out of plane by the compression in the webs. He felt that the tension in the bottom chord would hold the truss in line.
In the glulam trusses I deal with generally the tension in the bottom chord is very high in comparsion to the forces in the webs. Also the webs are often oversized just based on the width of the top and bottom chord and the depth that is practical to make a good connection.
In the case of metal press plate trusses every member is being optimized so I would think questions about bottom chord bracing would be more imporrtant.
As I stated before there are a lot of different opinions on this topic. What a particular engineer does may depend as much on the design practices of the engineers he or she worked with as any thing else.
The company I work for has several people with over thirty years of experience in designing with wood. Yet there are somethings those people don't even agree with each other on.
I would be surprised if this does not result in some compression in the bottom chord.
Regarding the bottom tension chord restraining itself from tension. It is not that difficult to check, take 1% of chord forces as a lateral load on the bottom chord and treat like a cable with tension equal to that from bending. See what the deflection needs to be to resist this lateral load and compare to what is acceptable.
Alternatively, you could widen the spacing and call up double trusses with a 2x6 on flat under to provide lateral restraint ( have done this in Australia for a few 40 or 50' trusses in schools).
In this particular case, (the building is about 30 years old), I guess the "test of time" has shown that bracing is not required.
Thanks again,
Larry Hauer
woodengineer
The point I was making is that it is impossible for the bottom chord to buckel if it is always in tension, regardless of how large the compressive forces are in the webs. Does anyone disagree with this statement?
