Flat Pattern Issues
Flat Pattern Issues
I have started at a new company and it is more sheet metal based than where I was at before. with that being said, we are experiencing some issues with the trying to create the flat pattern on the detail drawings. We have designers and detailers and the designers do not want to give the detailers write access to the part files that they are detailing from. When you try to create the detail of the flat pattern Solidworks wnat to create a configuration for the flat and write this to the part file. Well the problem lies if the part file is write protected then it can't finish the operation. Has anyone else experienced this problem and have you found a solution that will allow the write protection to stay in place?
drhinehart
drhinehart
RE: Flat Pattern Issues
SW07 SP2.0
Flores
thanks for the input..
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
