coolant / water separator
In our Machining Dept. we use a water soluble coolant ( cutting fluid ). We would like to reduce the cost of disposal of the used coolant by removing the water content which is approx. 94%. Does anyone know if there is a separator available which can remove the water clean enough to put in the drain.
Thank you
Thank you
RE: coolant / water separator
