Corroded Steel Columns
We have a case where the bottom 6" to 8" of the steel columns, supporting a residential appartment complex, have lost about 25-30% of their properties to corrosion and have to be retrofited. The columns are encased with concrete for what appears to be fire protecion and the bottom 6 to 8" portions are embeded into the concrete slab. The building is about 40 to 45 years old and there are no drawings available. In addition, the steel members do not appear to be close to any members listed in AISC.
Questions:
1. Where can we find properties for these members if any
2. Are there any pitfalls in dealing with this type of structure?
Any recommendations will be appreciated
Questions:
RE: Corroded Steel Columns
Can the lower portion be encased in new concrete to provide sufficient strength? It may be necessary to weld studs/lugs/straps/etc. to it to develop the new concrete.
It is possible to weld straps to the faces of the columns to build up the material as required.
Dik
Thank you for your information.
Dik
AISC Design Guide 15 Link
