Fixing Auxillary View Arrows
Is there a way to fix the view arrows so they don't slide around? I used the edge of the part to generate the auxillary view.
Thanks.
Sylvia
SW2007 SP1.1
Thanks.
Sylvia
SW2007 SP1.1
RE: Fixing Auxillary View Arrows
They shouldn't move unless you grab-n-drag them.
It shouldn't matter too much if your aux view arrows are not positioned exactly. What matters most is the viewing angle. As was said, don't move them and they shouldn't move (unless something changes in your model).
http://www.EsoxRepublic.com-SolidWorks API VB programming help
